Help with Contur 94 does not turn on
11 years 11 months before #44778 by manual-mecanica
Manual-Mecanica response on the subject Help with Contur 94 does not turn on
Hello, to see if it will be a problem in the DIS? But do you say that the injectors run out when you turn the start? Some fault of the crankshaft sensor ... I don't know if you will look at this ... or the relay that commands the injection. Well, everything, step by step not to go crazy.
11 years 11 months before #44805 by manual-mecanica
Hello everyone and especially thanks for continuing with my problem, I also suspect the TPS and the MAF in fact the TPS is the only thing that I need to change here are the videos that
the first one had told them is with the engine on and underway minima observeb that in the end it goes out when
the second is accelerated is maintaining the accelerator in a position
and the last one because without words it
is not possible to let Riel of the injectors and I realized that the 4 are injecting at the same time I already went for the fault of the computer already byobe with 3 and the same thing I tell you that you only need to try the TPS and the Camchaft in addition to what I realized is that they put a barrie to the dentate ring
11 years 11 months before #44806 by manual-mecanica
11 years 11 months before #44807 by manual-mecanica
11 years 11 months before #44808 by manual-mecanica
Here the friends friends
