clutch problems
17 years 4 months before #3884 by manual-mecanica
Clutch problems published by Manual-Mecanica
Hello everyone, I am new on the subject so please do not get a lot of tralla.
My problem is as follows: I have a Seat Toledo of 93 that when I step on the accelerator little more than the clutch skate, and therefore I despair if I want to advance or simply accelerate: Angry :. The poor is done dust and I want to spend how much possible to fix it. Therefore I would like to know if there would be any way to tighten the clutch or something, without having to buy a new one.
Well nothing, I hope someone can help me solve the problem with the clutch. All the best
17 years 4 months before #3887 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the clutch
The only possibility would be that the clutch was very tension and that was the reason why it is skating, otherwise there is no other option but replacing it with a new one, of course that if you do not have money you can make it to rivet although it is not recommended but it is very cheap.
17 years 4 months before #3918 by manual-mecanica
Miracles are made in heaven on earth do not exist.- If your clutch is with hydraulic bombin there is nothing left but to disassemble the change and see what is spent and if it is a mechanic with Guaya and that you can regulate there is that you can play a little. Greetings Alf.-
17 years 4 months before #3983 by manual-mecanica
That I can tell you Alkorta123 You must first see if it is hydraulic as the good short circuit says and if so I do not know if you have noticed if the pedal loses tension when you step on it since when losing tension is as if you were releasing it and at the time of releasing it it is almost outside and that can be the reason of the skated Above the three quarters of the height and there you must feel the improvement and if not, to change it for a rebuilt for while you grab the wool I hope and serve you my opinion and lucky and tell me what happened bye.
