Chek Engine
12 years 4 months before #40965 by manual-mecanica
Chek Engine published by Manual-Mecanica
;) I have the P0073 code in a Craisler Caravan 3.3 2006. It tells me that it is a ambient air sensor if it were so correct where this sensor is located thanks
12 years 4 months before #40976 by manual-mecanica
Manual-Mecanica Answer on the Chek Engine
Good I have a 4runner 96 the Chek Engine is burning because of the idle Speed ​​Control changed it and follow and who can help me
12 years 4 months before #41000 by manual-mecanica
Hello this sensor is located in the air hose that goes to the filter has the appearance of a phosphorus head
12 years 4 months before #41001 by manual-mecanica
Hello, if you already changed the valve and the engine is in its normal march that does not present any anomaly you have to turn off the witness with the OBDII or disconnect the battery the negative pole for about 30seconds
12 years 4 months before #41010 by manual-mecanica
Hi Foros Find the ambient temperature sensor, it is located below the motor radiator behind the bumper, it was changing it because it was attached to 78 degrees and goodbye problem. I hope this data serves. Chao Friends Foros
