Problem with my Hyundai elantra
12 years 9 months before #40709 by manual-mecanica
Problem with my Hyundai Elantra published by Manual-Mecanica
I told him a few months ago my car heated and bounced all the water for the deposit of the boiling radiator, the last tests I did loot the hose that comes from the engine to radiator and bounce I started better than what I expected the perfect sound but the problem happened to me the same as the same symptoms bootes the water by the deposit the only one and a great doubt that I have the original radiadior and it has sample of saro or oxide can be the problem that does not lower the appropriate water and that is the symptoms, I still do not put the main car my car is a huyndai elantra 93 1.6 doch, if it can already be. Thanks for your comment.
12 years 9 months before #40710 by manual-mecanica
Manual-Mecanica response on the problem with my Hyundai Elantra
It could be that the radiator this dirty would have to cake it or clean it by putting air inside the radiator A precion to release the precion so that the tartar loosen and fence out is my humble opinion
12 years 9 months before #40711 by manual-mecanica
It could be that the radiator this dirty would have to cake it or clean it by putting air inside the radiator A precion then release the precion so that the tartar loosen and fence out is my humble opinion
12 years 9 months before #40724 by manual-mecanica
Hello friend ... I already put the original plug to the radiator --- the fan is working ....
12 years 9 months before #40738 by manual-mecanica
That happened to me but it was because the thermostat's menbrane did not want to open, if the water does not circulate, it is heated in a sceso and the pressure takes it through the valve that the plug has. Clean the water circuit and everything will do well.
