GLOF 1990 Poles and Acite towards the filter of
12 years 11 months before #39053 by manual-mecanica
Please I need your wisdom. I have a 1990 golf that was fine until a few days ago I is throwing oil from the head of the head of the oil filter. Check my filter and I was totally soaked with Acite. My question (I suspect the compression escapes inside the engine) where can this leak be? In rings, valves, or that can be what is annoying me. Two days ago I almost left in 25 kilometers almost if oil. I also notice what is pressed by the acite measuring rod
12 years 11 months before #39061 by manual-mecanica
In general, this failure is the product of the compression starting to the carter, this is the fault of oval rings or cylinders.
12 years 11 months before #39064 by manual-mecanica
Check the carter's breathless hose, it is from the air filter to the cylinder head, I walked once and bounced oil to the cranks of the crankshaft, I do not know if that is the corduroy but it is easy to check and it is not others to check it.
12 years 11 months before #39067 by manual-mecanica
From what you had or broke some ring or the engine is very low of compression if it blows through the oil rod as sure are the hoops, oil consumption can also have for valve guide oil stamps that mileage and what model is 1.6 1.8 gasoline or diesel? What gets wet is the air filter with oil because it is not clear to open the orders
12 years 11 months before #39068 by manual-mecanica
I already check the hose and relief valve that it carries and it is not there:( I think it will be the rings.
