Toyota Corolla brakes problem 2005
13 years 6 days before #38499 by manual-mecanica
Toyota Corolla 2005 problem published by Manual-Mecanica
I have a 2005 corolla and when I am going to stop with some force, they are blocked in front wheels and crawls, the car does not have, only 4 -wheel discs, it is as if the rear wheels did not stop well.
Has anyone seen this problem and how to solve?
Thank you
13 years 6 days before #38508 by manual-mecanica
Manual-Mecanica Response on the problem problem Toyota Corolla 2005
What is ABA? If the front wheels are blocked or the traceras do not stop?, define a little more, to help you better
13 years 3 days before #38592 by manual-mecanica
Thanks for your interest in my problem.
I will try to better explain what happens.
The car is an XLI 2005 Corolla, 4 -wheel discs without ABS.
If the brake is used in a normal way, the problem is not appreciated since it stops moderately well, but when you want to demand the brake or press it with more force to perform a faster braking, the car is squeezed on the pavement and it is observed that smoke comes out of the front wheels, not the rear.
I checked the 4 wheels, if Ben are not new, they have enough useful life.
This brake is supposed to be efficient for having records on the rear wheels.
I have a Sentra II and the brake is far better and that uses tiles on the rear wheels.
If you have any track of what may be happening, I would appreciate it.
Greetings
13 years 3 days before #38595 by manual-mecanica
The four -wheel disc brakes all have a braking regulator to first stop the front wheels and then slow the rear so you say I think it is normal what it does anyway anyway you would have to go through the Toyota to check if the rear brake pressure is normal or effective.
13 years 3 days before #38613 by manual-mecanica
Change the dosing that is mounted on the Pered de Fuego will cost you new about 200 dollars this is the problem in this car but it is not so unusual what happens to you but when damaging it aggravates
