EPS witness ignition 2006 AT
13 years 2 weeks before #38296 by manual-mecanica
EPS witness ignition 2006 AT published by Manual-Mecanica
This week the EPS witness of my Accent 2006 AT has been lit three times and the tarne of Tranca and I cannot make turns. How this problem is solved since it is due. My car is six years old and I have never had problems so far.
13 years 2 weeks before #38308 by manual-mecanica
Manual-Mecanica response on the subject of the EPS witness of the Accent 2006 AT
Hello,
look that model brings direction assisted by an electric motor, it is most likely that the system is failing, so the address is tough you must check the system as soon as possible you could have an accident I think it is going under the Good Look steering wheel
13 years 2 weeks before #38326 by manual-mecanica
Indeed, it is electronically assisted address and that fault is done a lot in Chile in Chile Hiunday had to answer for that fault since it was presented in almost all vehicles, solution installs a hydraulic direction or replaces the body of the electronic direction
13 years 1 week before #38366 by manual-mecanica
Hello that witness turns on when you have a problem in the assisted address system, you should consult with someone who has a compatible diagnosis scanner and this will help find the fault
