speed indicator does not work normally
17 years 5 months before #3670 by manual-mecanica
speed indicator does not work normally published by manual-mecanica
First of all, I want to thank the people who keep this page for me have been very pleasant help.
I go to detail my problem.
I have a Maxima year 1992 of 3000cc., V6, Motor VG30 (E).
My problem is the speed indicator that when starting does not tell me what speed I have at that time. After a while the needle starts Amarcar.
The problems that conyeva apart from not saving the speed is that at first it has no speed and does not pass the changes correctly, when everything is normal again. I have registered the sensors and cables that I think it has a relationship and I have not achieved any result.
I hope you have an answer by this means.
17 years 5 months before #3673 by manual-mecanica
Manual-Mecanica response on the Re: speed indicator does not work normally
Hello if your car has a sensor in the change and as you say you have checked the cables it can be the sensor if instead you have Guaya from the change that goes to the board can be the cable or the guaya that is breaking if it is electronic with a diagnostic computer you go by the section of the board and there it can reflect some error, if everything may be the gear that is inside the change or the one that has the sensor that is spent. Check and let me know. Greetings Alfredo.-
17 years 5 months before #3702 by manual-mecanica
Sure problem is on the board needle greetings
