Airbag Xantia witness
13 years 3 months before #36345 by manual-mecanica
Manual-Mecanica Response on the Re: Airbag Xantia witness
Compa, we are giving you data where to check so you can save some tickets but, you must put will and check them. The airbag come from the simple with bag in the steering wheel, to which it brings fulminant in the belts and bags on all doors and depending on the country you live, connecting a scanner can cost up to 100 euros just for the diagnosis. Maybe I do not have the right of what your problem is but at least one guide I can give you.
13 years 3 months before #36526 by manual-mecanica
I sincerely lean more about what Daniel says. I had a Peugeot 406 and the same thing happened to you. It was the cable under the seat, there were times when the seat moved or if it was touched by what was turned on the happy light, in the workshop to which we carried it they turned off the light with the machine. What is important is that when it comes to passing the ITV, at least in Spain, you turn it off since otherwise it would not happen.
Obviously I am not saying that what WTO Electro says is not true, but I talk about my experience and since we put ourselves we are going to discard the easiest. Greetings
