Peugeot 406 TD 1998
13 years 3 months before #36045 by manual-mecanica
Peugeot 406 TD 1998 published by Manual-Mecanica
Hello friends:
I have a problem with the car, every morning when the engine is cold, aranco and I fall a drop of constant diesel as for 10 minutes, then stop the drop and until the other day it does not lose anymore, I do not find where it is the loss, they could tell me what I can do.
Thank you.
13 years 3 months before #36049 by manual-mecanica
Manual-Mecanica Response on the Re: Peugeot 406 TD 1998
Specifies Don de is that the drop falls
13 years 3 months before #36051 by manual-mecanica
Tomorrow I take the play and I look, and let you know
13 years 3 months before #36056 by manual-mecanica
It happened to me with a Nissan D22 was the fuel input hose, the new abrasing change and to date all perfect, and it was only in the morning the rest of the day or a problem.
13 years 3 months before #36065 by manual-mecanica
Estimated I was reviewing the loss you don't see anything there is not much space.
And above the pump there is not a drop, below it does not look much but the diesel comes along the road where the dentated strap and tensioners are.
After a while of checking I saw that the loss comes below the pump on the left side I don't have much to look at but a drop is seen.
Where can it be.
What ago ?????
