Isuzu Rodeo Motor 2001 V6
13 years 3 months before #35968 by manual-mecanica
Isuzu Rodeo Motor 2001 V6 published by Manual-Mecanica
I need help with the cam tree trees diagram of an isuzu Rodeo 2001 V6 CN Double cam of cam. In other words, time was lost and they have not been able to synchronize or put ready. If someone could help me, I would appreciate it very much.
13 years 3 months before #36017 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Isuzu Rodeo 2001 V6
Friend your engine brought a stabilizer in the crankshaft is to say a metal piece as a helmet with two gears inside and some counterweights ???
13 years 3 months before #36021 by manual-mecanica
I don't know if I brought it, I tell her that the truck is from my sister and she took it to the mechanic and recommended changing the headfolds and rectifying it, they did it but they disassembled the camshafts and the brands are erased and now they fail to put it on time, here in volcan Cam trees.
13 years 3 months before #36085 by manual-mecanica
Hello good night you will have the exact engine model since it is not enough only with the vehicle model and engine type (V6) in the Blok must carry the model for example 6ve1 is the case of some isuzu engines send me the exact model and so that market is that unit I send you the synchronization points greetings.atte, Luis Santiago
13 years 3 months before #36099 by manual-mecanica
Hello, thanks for the intention of helping me, the mechanic informs me that the engine is 6ve1 and it is a American version, Isuzu Rodeo of 2001. Any help I will be eternally grateful.
