Megane
13 years 4 months before #35947 by manual-mecanica
Megane published by Manual-Mecanica
I changed the 21 for a megane 99 K7M engine a week, oil began to pass to the water, I took the cyl lid. And I made it brush I changed together and the problem persists, I have the lid outside and in the hydraulic test does not jump anything, they told me that it could be the blok party in the oil climb but no crack is seen, what else can it be?
13 years 4 months before #35954 by manual-mecanica
Manual-Mecanica Answer on the Re: Megane
Good Leo, the hydraulic test of the cylinder cover does not indicate any failure and you already brushed your face. Now, most people do not know that the block of the block is also rectified, maybe it is folded, it happened to me with a samurai and I could not believe it. My recommendation is that you take the block to the rectifier to do the surface test.
13 years 3 months before #35981 by manual-mecanica
Pog fix where the oil filter is if it brings a heat exchanger if it brings it you can have problems with that part and nothing else, the solution is simple if the exchanger cancels making a bridge between its hoses.
