SHP OF LIGHTS FOR A DAEWOO MATIZ
17 years 5 months before #3558 by manual-mecanica
SHAFT OF LIGHTS FOR A DAEWOO MATIZ PUBLISHED BY MANUAL-MECANICA
I have a Daewoo nuance and I would like to put a sneak so that when I remove the contact and I leave the lights on me. I would like to know if in the fuse box there is some compartment for that sneak
17 years 5 months before #3559 by manual-mecanica
Manual-Mecanica Answer on the Re: Schivate of Lights for a Daewoo Matiz
Use the board fuse or in the original radius connector you should have a cable or you can usal the lighter light cable or you can also put a relationship that when you turn off the car the lights go out the lights cutting the current that goes in charge of the lights sees what you want to do and if you need help, let me know Greetings Alfredo.-
