Vibration when braking
17 years 5 months before #3546 by manual-mecanica
VIBRATION When published by Manual-Mecanica
Hello my question is the following, I have a Ford Focus TDDI
of the year 2000 a few months ago I started the direction
when stopping and I changed the brake discs but following the same
took it to a workshop and they rectified the records but at two days I still took it again to the teller and they changed my arcs and bearings again but the car
remains the same does not know that there can be someone can tell me what can happen to me.
Thank you.
17 years 5 months before #3547 by manual-mecanica
Manual-Mecanica Response on the Re: Vibration when braking
Hello my name is David, I read your problem, I would advise you to check the address terminals, because if they changed the album I imagine you cam, the pills bied, and then the same thing happened to you again, check the brake pump and will have an alignment and balancing of the wheels, verify if in 80k/h vibrates the direction without stop But you brake.
I hope to help you in something, luck.
17 years 5 months before #3548 by manual-mecanica
Hello albuerne, you are sure that the pastijjas of that car mounted you, it may be that they have set up alfun spare that is not theirs, take it to an alignment bridge and make it check their lower arms normally when they are damaged the bushings tend to vibrate or can also be some broken motor support, make them control and let me know I greet you.
17 years 5 months before #3626 by manual-mecanica
They have to look at you with a comparator watch the eccentricity that the busro is apart from the discs. Surely the problem comes from Aki.
The rectified discs can only be done once, and they also have to be placed. It is not worth letting the discs and leading them to rectify, so it does not clean the slack it can have.
If you have rectified it well, and the records have changed the problem will be the bushing, it will not be the problem of direction label.
Change the bushing and bearing.
17 years 5 months before #3659 by manual-mecanica
Hello albuerneque I spend your problem solve it and if so, you did greetings Alfredo.-
