Failure in Nissan Cabstar, loses power
13 years 5 months before #34500 by manual-mecanica
Failure in Nissan Cabstar, loses power published by Manual-Mecanica
How such, hopefully someone could guide me about this fault. Where we work we have a flotilla of this type of unity and the truth is that this fault cannot be found.
The fault is that suddenly the vehicle puts "donkey" or loses power and no matter how much you do not accelerate, so that it is corrected you must turn it off and when it starts again it is composed.
It is already sent to check the injection pump to the laboratory and they told me that it is perfect. System is purged filters and odes are changed the fault is presented.
He took it to the agency and they told me that the problem was that the injectors were deprogrammed and had to re -program them with a team that only they have, well, they let them do it and soon the fault has been presented again.
13 years 5 months before #34503 by manual-mecanica
Manual-Mecanica Response on the Re: Failure in Nissan Cabstar, loses power
Do you have the Camonn Rail injection? Czech the electronic accelerator always eat with that fault.
13 years 5 months before #34508 by manual-mecanica
Why don't you change the manual pump and you put another with removable metal antirectors that can be cleaned
13 years 5 months before #34649 by manual-mecanica
Well, let's start with the accelerator, there I talk to you as we are doing.
By the way, we could already get the code it throws and it is the P1272
13 years 5 months before #34803 by manual-mecanica
Apparently the problem was already corrected. We change the sensor that brings on the accelerator pedal and has no longer failed.
Thanks for the help.
greetings
