Astra 1.8 2001 start failure
13 years 5 months before #34492 by manual-mecanica
Astra 1.8 2001 starter failure published by Manual-Mecanica
I have an Astra 1.8 2001 (automatic), I have battled a lot with this car, stop it because it started to tremble a lot, I found a camshaft sensor with peeled cables and the water pump almost tied, I make the change of the water of the water and repair the sensor, synchronize the band as it indicates the manual (lifting trees with grimace up and crack car does not start, which can be.
13 years 5 months before #34504 by manual-mecanica
Manual-Mecanica Response on the Rera Smart Failure 1.8 2001
did you move the captor? You may not be reading or that you are not working, Czech whether or not there is a spark in the cables
