Resistances in spark plug cables ???
13 years 5 months before #34467 by manual-mecanica
Resistances in spark plug cables ??? Posted by manual-mecanica
Hello, greetings to all here.
DAYS I did a resistance measurement to my spark plug cables, being these:
1.- 3.48OHMS
2.- 3.30OHMS
3.- 3.83OHMS
4.- 3.83OHMS
AND DISTRIBUTOR TO DISTRIBUTOR CABLE 21KOHMS.- I think that the coil is very resistive, although I do not notice that the engine will work irregularly, also use resistive spark plugs. What they tell me is good to use resistive cables and spark plugs. These values ​​are within normal?
Greetings
13 years 5 months before #34469 by manual-mecanica
Manual-Mecanica response on the Re: resistances in spark plug cables ???
1.00 linear cable meter <= 20,000 OHMS 20 K OHMS
0.75 linear cable meter <= 15,000 ohms 15 k ohms
0.50 linear meter of cable <= 10,000 ohms 10 k ohms
0.25
linear meter of cable <= 5,000 ohms 5 k ohms And check that spark plug is recommended for your vehicle Note: Check the cable connectors that are in good condition and measures the cable, take out the percentage thus you will achieve an optimal measurement.
13 years 5 months before #34471 by manual-mecanica
Thank you nismo_35 for your answer. Analyzing your data the values ​​for spark plug cables would be fine, not that of the coil to the distributor is very high. Looking at Autodata this with the correct spark plugs Bosch WR8DC for a Toyota Corolla.
Have a good day.
