My Jeep Grand Cherokee 1995, goes out down
13 years 5 months before #34450 by manual-mecanica
My good friends:
I have a Jeep Grand Cherokee 1995, 4x4, 8 cyl. And it goes out when the speed is decreasing, as an example, when stopping to pass a stop, the RPM gets down to zero and turns off.
To recommendation, I have replaced the crankshaft sensor, air and gasoline filter, spark plugs, cleaning body cleaning, verify and all the fuses are well, it does not give me any fault code; I'm going to change spark plug wires, and it's still the same. So I will appreciate tell me what I can do the most. Change the computer?
13 years 5 months before #34452 by manual-mecanica
Check your air decontrol valve (IAC)
13 years 5 months before #34459 by manual-mecanica
command to clean the acceleration body and verify that the mileage functions because the sensor is damaged produces that fault but first clean the acceleration body
13 years 5 months before #34483 by manual-mecanica
I already clean the acceleration body and the IAC valve, and the failure continues to be presented. I will continue with the PCV valve. Thanks for your orientation.
13 years 5 months before #34484 by manual-mecanica
My good friend, I already cleaned the acceleration body and the IAC valve, this is not possible to check its status with the Scaner, I will clean the PCV valve and see what an answer I get. I am thinking that it could be the computer. What do you think, thanks.
