Problem with a 2kd Turbo Intercooler Toyota engine
13 years 5 months before #34312 by manual-mecanica
Good friends from the forum: My problem is, I have not just finished repairing a 2kd Toyota Turbo Intecoler 2008 engine, at the time of turning it, normal turns on without problem, I do not vote for error code (check), the problem is that when trying it and does not answer me, it has no power (reaction force) could help me that sensor influence failure. Thanks .. any help will be good.
13 years 5 months before #34324 by manual-mecanica
Hello,
if the acceleration does not exceed 2000 to 2500 rpms, I could tell you that the problem is in the MAF sensor (air mass). With prior authorization from the client, you must clean it with a clean contacts (if possible, quick drying). Apply it from afar, let the dirt drain and dry alone. For no reason to touch the internal filaments.
You should also check if there are fault codes to guide you with other related problems.
13 years 5 months before #34333 by manual-mecanica
The problem was in the air flow that is lodged in the air filter housing .. The connector was half soil of ESOO was that the computer did not detect the air inlet well .. it was connected correctly and we tried it again and the truck reacts normal ... thanks for the fact fernadocies ... for another moment I will have very much the connectors of the sensors that are well connected ... thanks ... thanks .. thanks .. thanks .. thanks .. thanks .. thanks ...
