Problem with the back of the Suzuki Wagon R
13 years 5 months before #34273 by manual-mecanica
Problem with the back of the Suzuki Wagon R published by Manual-Mecanica
I have a 2002 Automatic Wagon R and when the car heatrates and placed back a few meters and it is tranca, that is, you have to accelerate a lot for the car to boot (in setback), the speeds in front do them well. If someone can help me, I would appreciate it ...
13 years 5 months before #34291 by manual-mecanica
Friend, most likely you are having Cloht problems, when the album is very thin or crystallized, that goes out, it goes out because it no longer manages to release the speed. Also passing the press, because if the album is fine, it could be that. Because unless you have problems with the other velosities that may be looked perhaps and only, the synchronizer of the box can fail, but that stops it finally because it is quite unlikely. B)
13 years 5 months before #34294 by manual-mecanica
If it can be what you say but the car does not go out and it seems that it has two speeds, that is, setback and first. Well, the first thing I am going to do is clean the valve body and if it does not improve it I would have
13 years 5 months before #34363 by manual-mecanica
Friend the problem was in the body of valves that was dirty with chips that trant the valules ... the car was fine. greetings.
13 years 5 months before #34396 by manual-mecanica
I'm glad you will find out and thanks for the info that helps for futures, :)
