consultation
13 years 6 months before #34236 by manual-mecanica
Consultation published by Manual-Mecanica
Hello friends, I need to know a list of vehicles that have obd2 or how can I know if they have this protocol or other greetings and thanks to everyone they give me an answer
13 years 6 months before #34238 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
Ok friend most vehicles with the OBD2 system are from 2000 but not all has to verify if in the Scanner connector it has 16 pins many take it from the low Izquerdo side of the steering wheel or under the rifle that area more than everything is located the connector for OBD2 anyway you send you a photo so you can see how the connector is
13 years 6 months before #34239 by manual-mecanica
www.google.co.ve/search?q=Obd2&hl=es&prm...lae&biw=1024&bih=649
In this link you will get how is the connector and position of the cables as they have to go
13 years 6 months before #34240 by manual-mecanica
Thanks friend you've been helpful greetings
