Motor without power
13 years 6 months before #34132 by manual-mecanica
Manual-Mecanica response on the Re: Motor without power
Of you I would check the draft of the distribution and fuel pressure, from there you will know whether to remain mechanically or in electric ... by the way to look at compressions would help. Greetings!
13 years 6 months before #34173 by manual-mecanica
Thank you for the comments, the car is an ATOS 2005 model 4 5 -speed standard transmission cylinders and it is from the hruay and distributes the Dodge in Mexico and as I said at the beginning when I register in mechanical manuals: I am not a mechanic but I like to move my cars and when I cannot ask for help. Check the gas feed lines. I gave them a torch, lower the gasoline tank and gave it a washing and change the golin filter, which was very dirty, and if there was a very noticeable change the engine work is heard with more power already gives the accelerated one that according to me is required, only very occasionally Acceleration body since disconnected works very accelerated and without connecting it is heard that the air is missing, it is only an economic question to be able to change it and see if the fault persists to check other points, because I think that with the help of you I am fixing it better than the mechanic that I have of ate, so I have nothing left but to add much to me
