BT-50 FLOWJOMETER FAILURE
13 years 6 months before #33985 by manual-mecanica
Manual-Mecanica Response on the Re: Flow Fall BT-50
Ok we expect the review report
13 years 5 months before #34457 by manual-mecanica
There were 2 injectors covered by diesel contamination, the owner had filled oil from a drum ... we changed 2 injectors and the problem was solved. Thank you to those who contributed with the information
13 years 5 months before #34461 by manual-mecanica
Some questions:
* In which country are you
* cost or value of the two injectors
I recommend installing an additional filter to avoid these damages, of course if you are sure that the diesel you sell you are not contaminated there is no reason to do so
13 years 5 months before #34486 by manual-mecanica
I am in Chile and the cost was approx. 440 dollars
13 years 5 months before #34498 by manual-mecanica
If it has bells it is detonation and it is a product of problems of synchronism, it would be good to check the tuning.
