Battery charge problems
13 years 6 months before #33923 by manual-mecanica
Problems with the battery charge published by Manual-Mecanica
I have a Volkswagen Amazon cart of 82 this cart better than a 4x4 did not give me problems like the other one that I have until one day I stopped turning on the light of the battery board I thought it would be that the LED had been burned but the LED had not been downloaded distributor cables and my digital multimeter brand of everything except a stable reading some idea that may be
13 years 6 months before #33927 by manual-mecanica
Manual-Mecanica response on the Re: problems with battery charge
Greetings Firefox, the common diagnosis with the voltimeter is to measure the voltage in the battery (approximately 12.6V) with the engine off, then proceed to measure with the engine on (it must reach approximately 13.8V), if the reading differs from this there are problems in the alternator, a low voltage can indicate various damages from brooms, rotor, regulator, diodera ... A high voltage is usually damage to the regulator. From what you indicate there is damage to the alternator, command to check it and tell us. Greetings.
13 years 6 months before #33940 by manual-mecanica
I agree with Wolfi everything points to a damage in the alternator so that more explanations Wolfi already told you all luck.
13 years 6 months before #33949 by manual-mecanica
Thanks for answering so fast. They are what they tell me but for my work I will do it on Saturday on Monday
