Problems with a kia picanto
13 years 6 months before #33572 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with a Kia Picanto
Have you changed the air valve that tells you?
13 years 6 months before #33573 by manual-mecanica
If you change the ISC valve and follow the fault
13 years 6 months before #33591 by manual-mecanica
You should check several things:
first you should observe that there are no parasitic air inputs, that the entrance hoses to the secondary air injection valves (they are the codes that you show you the scanner) are well placed and are not cracked, you must check if they are in the right order and if they do not have any problem in the electrical installation, that is, the connector is not making a bad contact, you should not check that you should Valves are not too hot, because this sometimes indicates that they are looked and they remain open !! Then you must check with the scanner that the computer does the closed pedal switch to enter the idle and check the pedal signal to WOT.
Greetings
