Re: Chevrolet Corsa 1.6 overheating
13 years 6 months before #33503 by manual-mecanica
Re: Chevrolet Corsa 1.6 overheating published by Manual-Mecanica
I have a Plus Corsa overheat has a lid of the original deposit has 2 fans and they work when the needle is in the middle of the score out
13 years 6 months before #33505 by manual-mecanica
Manual-Mecanica Response on the Re: Chevrolet Corsa 1.6 overheating
Hello, I suggest you review the issue of the water pump that it has to have the same dimensions so that it can work properly, but if it were the case that this is okay it begins by inspecting the thermostat, water temperature sensor, refrigerant container cover, radiator has no pollution that can obstruct the refrigerant passage, separately revive 100% if electrventillars and temperature sensor work
