The yellow light was turned on as when the vehicle is on wet floor or is skiding and stops in speed,}
a f 150 double
cab Blocking does not work the immobilizer with the scanner I get that the signal of the immobilizer does not agree with the VCI or BCI I do not know how it is ,,,, but I turned on the car for 30 min when I changed the shoppinger with that of another car but they ended up blocking the two to take them to the Chevrolet and they told me that they do not know that it would be like to know that it is. Problem, to another vehicle with the same problem, the BCI changed the computer the computer the immobilizer and oviously the key with the chip but it came out very expensive and not to all customers I can tell you that I am going to do the same and there is no way to reprogram it with the tech 2 and attempt in a thousand ways thanks for the comments
