I would like to clarify a doubt
13 years 8 months before #33262 by manual-mecanica
I recently purchased a jump-starter system, and the manual mentions terminology regarding how to connect it.
It refers to a system with negative ground and a system with positive ground. Could someone explain what each of these terms means? Thank you very much for your attention.
13 years 8 months before #33291 by manual-mecanica
Manual-mechanics' response on the topic Re: I would like you to clarify a small doubt
That "terminology" refers to how the electrical system is connected in the car.
But the correct way to connect it is from the jump starter's positive terminal to the car battery's positive terminal
, and from the jump starter's negative terminal to the engine ground.
Engine ground is any metal part.
Remember:
positive = red wire = (+)
negative = black wire = (-)
