Ford Fiesta Year 2001 Intermittent Problem
13 years 7 months before - 13 years 7 months before #33189 by manual-mecanica
Ford Fiesta Year 2001 Intermittent Problem Published by Manual-Mecanica
Hello everyone;
For a while since my Ford Fiesta, when they think, stop working when they have already been operated. To recover them I have to put them out and put them again, be it to indicate the direction or the emergency.
The lights work both inside and outside, I think it can be the relay, because the levers do not give me any problem with the other functions. What do you think?
Thank you so much.
Last edition: 13 years 7 months before by .
13 years 7 months before #33192 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Fiesta Year 2001 Intermittent Problem
Hello friend in my workshop I arrive a party with that problem and it is internal on the lever you have to disassemble carefully but if you do not have much experience, take it where an electrician xq will be difficult to be difficult has many delicate pieces and you will not be able
13 years 7 months before #33193 by manual-mecanica
Friend, if the problem is also in directional and not only in intermants the cause is not on the lever of the directionals (since they direct voltage to the same point, they are physically independent switches), but in another element that is after these switches in the circuit that goes to these lights. Personally, I would recommend locating the relay and/or flash and try it (s), as well as the continuity of the cables, the state of sockets, dirt or land in connectors.
13 years 7 months before #33220 by manual-mecanica
First of all change the flash and then if it does not work continues but usually it is a flash problem
