Hello, very good morning, the reason for the present is to request help with my vr6 96 jetta, I tell you the problem:
they would see two days ago my brother came from school, according to him, he made him angry a teacher and time to leave, I take the most free way back home, with the only intention of stepping on him thorough Approximately 25km at a normal speed (80) that is the most common we handle ...
at 15 km more or less, the car goes out in neutral speed, it was tried to turn on again, I turned on, but it went out immediately. And now if I did not turn on ...
In the first instance I thought it was gasoline, 4 liters were added, but no longer answered, then I realized that the camshaft sensor had loosen a cable, connect it but still not answered ...
yesterday I was checking it, we realized that I was not reaching gasoline to the engine, we went on the pump, does not enter, the relay does not reach the pump. The fuse and is located, but when checking voltage in the fuse input line I realize that it is not coming voltage, I decided to try the pump taking the voltage on the other hand, the pump does work, I went march but the same, it does not turn on, if you go, I do not think it is something mechanical, discarding that, I left on the spark plug wires, there is no spark Similar, take my hand for the truth I do not know what I can do
eh also that the glasses do not rise, they just go down ... I do not know if it is any symptom of something ...
