Problems with pneumatic suspension.
13 years 3 months before #33082 by manual-mecanica
Problems with pneumatic suspension. Posted by manual-mecanica
Hello! I have a Mercedes Vito V230td with rear pneumatic suspension. That suspension has been damaged and every 2 or 3 days I have to walk up and others. Someone could tell me if that suspension can be replaced by another normal? I mean by helical docks, they don't need a compressor.
type of springs and pieces and others.
Thanks, greetings.
13 years 2 months before #33277 by manual-mecanica
Manual-Mecanica response on the Re: Problems with pneumatic suspension.
You can replace the suspension with a conventional one like the one that the Vito carries without any problem.
But if the air leak you have is small, it will be cheaper to repair it since it is most likely that it is for the toric joints that the two rear pneumatic bellows and the closing valves carry.
It does not have much time in labor and repair games are very cheap.
It is original replacement. You don't look for repair games only in origin.
If the compressor is fine and the closing valves. Setting the joints is solved safe.
I want to think that the two rear bellows are also stagnant. But they are not as expensive as the modification of the suspension
a greeting
13 years 2 months before #33289 by manual-mecanica
Nothing else already Bonymore told you everything very successful the answer.
13 years 2 months before #33301 by manual-mecanica
thank you so much.
You would know how to tell me how to turn off the suspension failure indicator that comes out in the control table.
all the best.
13 years 2 months before #33303 by manual-mecanica
That you can only turn it off by repairing the breakdown, or taking out the spotlight if you are going to make the modification you mentioned
