TPS Suzuki Maruti
13 years 9 months before #32857 by manual-mecanica
tps suzuki maruti Published by manual-mecanica
Hi, I'm new to this forum.
I wanted to know if anyone knows if it's possible to make a TPS sensor with a potentiometer. I look forward to your reply.
13 years 9 months before #32860 by manual-mecanica
Manual-mechanics' response on the topic Re: Suzuki Maruti TPS
The potentiometer is the basic principle of a TPS, but there are ECUs that compare the TPS signals by having two potentiometers incorporated in the same TPS, so it seems somewhat difficult to do, but I suppose it is possible. Also, the resistance range varies from vehicle to vehicle.
13 years 9 months before #32874 by manual-mecanica
Greetings, for testing purposes or to rule out faults, you can use a potentiometer, usually 5Kohm, although it varies depending on the vehicle brand. However, leaving it fixed is not recommended since the potentiometer material is not designed to withstand the temperatures present in the engine, and it would wear out quickly due to the extensive use it would receive, as the material cannot withstand such use.
13 years 9 months before #32887 by manual-mecanica
It is possible, but you need to have the resistive values ​​and properly calibrate the splitting angle with respect to the potentiometer's resistive line. Also, the TPS has three tracks, which means you need three potentiometers that operate at 5 volts and they must also be connected to the corresponding ECU line. It's cheaper and less complicated to buy them.
