My fiat point is accelerated
13 years 7 months before #32817 by manual-mecanica
My fiat point is accelerated by manual-mecanica
Good
to see if someone can help me buy a fiat point 55s I have already fixed it but the problem is that it is a bit accelerated, so that the slowdown is in its normal value. Falling it a little you leave it for a while and it seems that it gets normal.
When under a slope I have to stop more than normal because it tends to leave.
I have not yet changed anything so I don't know if filters etc the time they have.
The only thing that changed was the Lamba probe that was beaten from the crash.
thank you
13 years 7 months before #32835 by manual-mecanica
Manual-Mecanica response on the Re: my fiat point is accelerated
Czech that there are no false air inputs can be there that enters air and accelerates you the other is that the Relay regulator is not regulating.
13 years 7 months before #32850 by manual-mecanica
The idle regulator is not excactly or where it is, this car is of monopunto injection, the strange thing is that you leave it for a while and gradually slow down until normal.
thank you
13 years 7 months before #32878 by manual-mecanica
Well it is Normaql that the cold game is accelerated but maximum 1500 rpm, and then when they heat they go down if it is monophen with injection Magneti Marelli has a body that is in charge of that, the temperature sensor can be damaged because it is a long time stopped and it acts directly on the Slenti Checalo is not expensive.
