Problems with an Astra 1.8 2001
13 years 3 months before #32735 by manual-mecanica
Problems with an Astra 1.8 2001 published by Manual-Mecanica
Someone can help me, an Automatic Astra 1.8 of 2001 made my car
13 years 3 months before #32737 by manual-mecanica
Manual-Mecanica Answer on the Rera Problems with an Astra 1.8 2001
Change the acceleration body because they made it losing the affination to see it moved with the hand and that no longer does
13 years 3 months before #32740 by manual-mecanica
Hello, your problem is very common, when you make the sure affination, the acceleration body also washed, with this moving the position of the acceleration butterfly, before changing anything, take your car to a workshop of your trust, so that with the help of a good scanner, they can synchronize the acceleration body of your astra, they surely solve your problem satisfactorily, hopefully you can comment on the results. I hope my comments serve you.
Atte. Isai Curiel.
13 years 3 months before #32742 by manual-mecanica
Greetings is correct what Curiel says you have to readjust the acceleration body with preferably Scaner with Tech 2 or another of good brand
13 years 3 months before #32862 by manual-mecanica
Take my car to scan it, it was not with Tech 2 only the agency has it, but all Monclova (where I live) go with this mechanic has something similar and could not calibrate the acceleration body, we got in touch with a mechanic of the Chevrolet and told us that the acceleration body is damaged and that these cannot be calibrated.
I wonder before changing the acceleration body, if I can do something else.
