Help Chevrolet Corsa
13 years 7 months before #32701 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Chevrolet Corsa
Greetings, right that is the measure that has 695mm
13 years 7 months before #32710 by manual-mecanica
Ok, if the arrows are new and the distance is specification there is not the problem.
I do not know if you already checked the wheel bulteria on that side of the vehicle, it is very easy (and do not misalk the car) if you disassemble the complete tower with shock absorber, you assemble the set in a gag and then with a screw (or homokinetic used) squeeze the beal, you turn the mace, check its adjustment and listening or feeling to detect noises, clicks or jumps that indicate a wear.
Other review points would be homocetic on the side of the speed box, or even the differential, although the latter is less common
12 years 11 months before #38767 by manual-mecanica
And well friend, did you solve your problem? It is always good to socialize solutions. Greetings
