Help Chevrolet Corsa
13 years 5 months before #32613 by manual-mecanica
Help Chevrolet Corsa published by Manual-Mecanica
Good afternoon I have a doubt about my Chevrolet Corsa 2004, 1.6 synchronous, I have changed the entire complete front train; I do not think that something is spent high x but when I start in 1st I jump on the side of the co -pilot I bone the right front rubber, what could that be ??? It already has me crazy and nobody knows what it is.
I have changed new gas shock absorbers, bottom stumps, terminals, rotulas, the 4 rubber stabilizer, the famous Murcielagos, the bushings of the address cat, the motor and box bases, the alignment is fine, the balancing is fine, even changes the rubbers from front to back and nothing and I do not know how to change or do?
I would appreciate your help or some track.
13 years 5 months before #32621 by manual-mecanica
Manual-Mecanica Answer on the Re: Help Chevrolet Corsa
Hello friend, did you control the motor and transmission supports? I had a similar problem and they were the supports, tell us, it is going, greetings. :)
13 years 5 months before #32639 by manual-mecanica
Greetings thanks for answering, how is it to control the supports ??? I send them to change, they are all new
13 years 5 months before #32672 by manual-mecanica
(... but when I start in 1st I jump on the side of the co -pilot, I bone the right front rubber ...) Necsites that you translate that to the Spanish language chilensis ... and more that I can help in your problem ..
13 years 5 months before #32674 by manual-mecanica
I Soty in Mexico and the model is likely not to properly see the support what the noise or jumps does, check your chassis, it usually happens that in the front the laminate is simply broken check the part that goes side to side to the height of the base of the radiator
greetings !!!!
