PEUGEOT 106 MAX Air Conditioning Problem
13 years 7 months before #32945 by manual-mecanica
Manual-Mecanica Answer on the Re: Air conditioning problem Peugeot 106 Max
Mra in detail it is not easy but if you went to a workshop they should locate it but in the outside rifle they have to try themselves the relex all are the same are the same tries to change the pososciom and so you will see which this bad is
13 years 7 months before #33086 by manual-mecanica
The AACC relay is the one in a box behind the battery taken to the chassis? I have opened it and 4 fuses appear and 1 reluctance would help me a photo of the hubication if this one that I comment was not. In the workshop they did not tell me where they were. Thank you.
13 years 7 months before #33155 by manual-mecanica
Check the Relex opening it very carefully and you pis as you will see what the Relex
13 years 7 months before #33363 by manual-mecanica
Hello everyone, I have already located the AACC problem, I have found 2 cut cables that leave the thermostat located in the part of the co -pilot area I have joined them and the compressor starts, I only need to know what piece I was connected in that place, I suppose it will be or a probe or a Valeo brand sensor, if anyone knows anything about the subject I would appreciate it, when I solve it.
