PEUGEOT 106 MAX Air Conditioning Problem
13 years 7 months before #32492 by manual-mecanica
Air conditioning problem Peugeot 106 Max published by Manual-Mecanica
Hello everyone, I have a probma with the AACC of my Peugeot 106 Max, the fact is that the compressor is not activated that I have gas load and so it is not cold air, on the other hand the internal fan of the habitaculus does not for Auquer is in zero position, can someone help me? Thank you in advance.
13 years 7 months before #32500 by manual-mecanica
Manual-Mecanica Answer on the Re: Air conditioning problem Peugeot 106 Max
It has a problem with the reflex or the suiche of speeds you have to check all the relex and verify if the coil is good by placing a direct cable to the compressor you also have to check the presustatic valves both low with high
13 years 7 months before #32504 by manual-mecanica
Thank you, now I have to find out where the air relex are, the coil and the valves is already great, I do not know how to do it I will try the first and I tell you the result, thank you again.
13 years 7 months before #32510 by manual-mecanica
Some cars have the function of launching the internal fan when you put the air conditioning, only the first speed if I do not remember. From the compressor what they have told you: Check the compressor coil and the prestostatic valve (or three functions) which is responsible for starting the compressor sent by the pressure of the circuit.
13 years 7 months before #32919 by manual-mecanica
Hello again I continue with the unsolved problem, take it to a Peugeot workshop and they told me that it does not reach the compressor that had to look for the electrical scheme to find out the breakdown, I still think it is a relay but I do not know what it is, you can indicate it with details to be able to check it. Thank you
