Ford Motor 292 V8 - Loss Power
13 years 7 months before #32489 by manual-mecanica
Ford Motor 292 V8 - Loss Power published by Manual -Mecanica
By accelerating Pirde Power. I changed rings and the second day of filming began the problem. Revice the carburetor pique pump and it works well. I made platinum tune, etc. Revice the benzine pump, all good, regulation of valves, does not suck air. It goes well but when it continues to accelerate, it empies to suck, and then it is long but when climbing another one the power is declined again as if they assumed and released it, I do not know what else to review.
13 years 7 months before #32501 by manual-mecanica
Manual -Mecanica Response on the Re: Ford Motor Truck 292 V8 - Loss Power
Hello chick.
How is the air filter? Check the exhaust tube and the multiple, which are not clogged with coal, for example, check the valve calibration. Luck.
Miguel
13 years 7 months before #32503 by manual-mecanica
Thanks Servilimit. The engine is cleaned complete including multiples, and valve calibration. La Revice.chisk
