Disassemble peugeot partner tepee trimming
13 years 5 months before #32421 by manual-mecanica
Disassemble PEUGEOT TEPEE GUARNEIDO PUBLISHED BY MANUAL-MECANICA
I would appreciate information on how to disassemble the trimming of the roof and trunk sides and column of doors in the Peugeot Partner Tepee vans.
With references to avoid breaking, it would be enough. Thanks in advance. Greetings to all.
13 years 5 months before #32448 by manual-mecanica
Manual-Mecanica Answer on the Re: Disassembled PEUGEOT PARTNE TEPEE GUARNED
What are the trim?
13 years 5 months before #32467 by manual-mecanica
They are the pieces that cover the sheet on the sides of the trunk, on the roof and at the doors. They make insulating noise function and protect while improving the finish of the finish.
I need to know how to disassemble, without breaking, the plastic plates that cover the sides of the Tepee partner and those that force the pillars between the doors.
Greetings and thanks.
13 years 5 months before #32478 by manual-mecanica
I know that we are talking about, friend I tell you those parts are usually joined to the cars by plastic croches, you should put a screwdriver in between, one ves So the world is not over, luck
13 years 5 months before #32494 by manual-mecanica
Thank you so much.
I'm going to try.
Although I think I am a bit little hands that I first break and then I have to fix.
I will tell how it is doing.
Thank you.
