Problems with Daewoo Cielo
13 years 7 months before #32418 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Daewoo Cielo
Hello, if your problem is the low compressions for me that your problem is not in the rings or shirts and less in the distribution, if you have changed everything new and you are a non -amateur technician you must have measured the slot of the rings involved in the cylinder without the piston. In addition the engines trbajan without problems even if they have the rings more than 20 thousands of inch. Check well that your problem could be in the seats of the valves whether they are very spent and that the buss do not let them close the valves or that they are burned if you did not send to check the cylinder head. Some mistake is fixed well that something simple has to be.
13 years 7 months before #32424 by manual-mecanica
Hello friend if you have the compression low and the whole engine has been repaired to the best one or several of the valves is badly established to try that you can place each of the pistons with the two closed valves in lower dead pint escape the one that escapes.
Another option would be that the rings were quickly spent (in this case you would have consumption of the engine oil) and this can be given by lack of lubrication in the tall shirts the lubrication holes that carry the rods are covered. But that check it out later.
13 years 7 months before #32449 by manual-mecanica
This is super easy to know, take out the spark plugs and made a little oil with a geringa and measures compretion if it works well is rings problems, and although as they say they should all be another extent, so only for life they do not turn, luck.
13 years 7 months before #32462 by manual-mecanica
Your problem is the rectification of the cylinder has too much oval eye. luck
13 years 7 months before #32691 by manual-mecanica
Thanks my Qrido friends, everything will see it ...... Then I will tell you .....
