Saviero when he turned it off, a light is caught
13 years 8 months before #32326 by manual-mecanica
published by Manual-Mecanica is caught
Saveiro 2010 when it appears it is on any light, I don't know what can be
13 years 8 months before #32333 by manual-mecanica
Yes, but what light is taught to give us a track?
13 years 8 months before #32340 by manual-mecanica
Sometimes the stop light that llva is on the roof or some back back when the contact closes
13 years 8 months before #32341 by manual-mecanica
Check the brake light switch, there are occasions that when the pedal is not operated, it fails to make contact with the switch and that is why the lights are set.
If you disconnect the switch the brake lights should not be lit.
13 years 8 months before #32356 by manual-mecanica
Mmmm I do not believe, the stop is of hand brake but it only turns on when the contact opens, if not, it does not pass the current towards it, and does not close the earth, for me that the teaching module of the sheet is badly working, if you do not kiee complicate your life put a short current that is the same is useful to avoid rovos.
