I made a bad bridge ...
13 years 8 months before #32222 by manual-mecanica
I made a bad bridge ... Published by Manual-Mecanica
Greetings to all;
I made a bad bridge by mistake by connecting the amperimeter between the positive and mass of the pump relay and the Daihatsu Terios does not turn on.
If any of you has the electrical diagram, I thank you.
Cordial thanks.
13 years 8 months before #32228 by manual-mecanica
Manual-Mecanica Answer on the Re: I made a bad bridge ...
Czech the fuses the most normal thing is that one is founded, but as advice he told you Czech if it does not start due to lack of spark or fuel, and then we take measures in this regard but we have to section the search field a bit, in addition it would be normal to affect a land so I tell you that it should not be anything Gtrave.
13 years 8 months before #32229 by manual-mecanica
Thanks for your interest in helping me:
I did the bridge between terminal 86 and 85, that is, among the positive of Swicht and computer mass with an amperimeter.
