the starter engine is hooked
13 years 3 months before #32218 by manual-mecanica
The starter engine published by Manual-Mecanica
I have a seat leon tdi and I get hooked on the starter engine I wanted to know what checks I can do or what will it be
13 years 3 months before #32219 by manual-mecanica
Manual-Mecanica response on the Re: the starter engine is hooked
Hello friend nachoracing, if your start is the same, try by disconnecting the connector at the start and putting direct corie damages another component.
13 years 3 months before #32226 by manual-mecanica
If when you say hooked, you mean that it is put on, or it is the contact sheet or it is the solenoid of the starter or starting pig I do not know how you know it, but it is easy to try a cable with two points put one to the nut that Biene from battery and the other to which it reaches contact sheet and the other end to battery if it is passed is solenoid.
13 years 3 months before #32272 by manual-mecanica
I have had that probation with several vehicles, that the start -up was taken and did not engage with the engine only one clip was heard, I have disassembled them and cleaned them with gasoline because with the carbon that Cria was grabbed, I have mounted and perfect, but I do not know if that will be your case.
13 years 3 months before #32292 by manual-mecanica
The problem is not that it does not start, when I start a noise as if the pinion did not go back
