AKT 110S Motorcycle Valves Adjustment
13 years 9 months before #32213 by manual-mecanica
Valve adjustment for an AKT 110S motorcycle. Published by manual-mecanica
Someone could tell me that calibration or adjustment carry the valves of the AKT 110s motorcycle. How I achieve the point
13 years 8 months before #33148 by manual-mecanica
Manual-mechanics' response on the topic Re: valve adjustment akt 110s motorcycle
Okay. The intake valve should have about 5mm of clearance, and the exhaust valve 10mm. You need to make sure you're at top dead center and the rocker arms are free when adjusting. Turn the flywheel one turn until you feel the valves are loose and the piston is at top dead center. The letter (t) should be aligned with the cylinder head.
