problem with Ford Focus 2000,
13 years 8 months before #32177 by manual-mecanica
problem with Ford Focus 2000, published by Manual-Mecanica
I have a problem with two injectors who do not work, they are open, current arrives direct.
13 years 8 months before #32179 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Ford Focus 2000,
Remember that they come positive and negative by exitation
13 years 8 months before #32181 by manual-mecanica
If both arrive negative and positive, you have to review the Relex if it does not arrive negative if not only x Exitation you must change the injectors now I have an equal problem but with the party and review everything and it was the ECU that was bad but to know if it is the ECU you have to scanar
13 years 8 months before #32193 by manual-mecanica
I tube that drama with the focus, it is the ECU the problem testing the computer output connector if you do not improve the sending to repair if you do not want to do that you have a bridge between the negative terminal of the injector that is directly next to the side and you can get out of the step, negative with negative Sipo Lucky Hahahaha
