POWER LOSS IN PEUGEOT 206 1.6 NAFTA Motor
13 years 8 months before #32160 by manual-mecanica
POWER LOSS IN PEUGEOT MOTOR 206 1.6 NAFTA PUBLISHED BY MANUAL-MECANICA
I have a engine problem, the revolutions are low, before at 3000rpm iva at 100km now at 3000rpm I go to 110km ... I also accelerated it suddenly in 5 and suviate the revolutions of blow now I do the same and not even there, it accelerates slowly looks like gasolo ... what will it have? please help ....
13 years 8 months before #32170 by manual-mecanica
Manual-Mecanica Response on the Re: Power Loss of Power Power 206 1.6 NAFTA
If handling in 5 notes that the revolutions rise but the speed does not, then we talk about a clutch problem, but if you have never made a refinement I recommend that you entertain it, also make sure that the escape line is not obstructed including Catalitical.
13 years 8 months before #32173 by manual-mecanica
Hello friend, I have the same problem and Admas I feel the exchange box that much thunder and also that sometimes I throw the change why that happens? is that of factory or a lot of use?
13 years 8 months before #32176 by manual-mecanica
Your problem is rare. Before 3000RPM I went to 100k/Hy now to the same RPM goes to 110k/h. That would lead me to think that you changed something in the transmission or put a different profile on the covers or tires of greater diameter. That would also explain the fall in the acceleration response. Greetings and luck.
B)
13 years 8 months before #32191 by manual-mecanica
That the march gives you is not normal, in addition the Peugeot boxes do not put any factory noise, I check the cash support if it has a game tends to take the march, in addition Peugeot uses a tensioner below the engine that when it is cut or game also makes that effect it is not expensive and at all difficult to change.
