TURBO DE PADIC
13 years 8 months before #32105 by manual-mecanica
Turbo of scenic published by Manual-Mecanica
Ola I have the 1900dti scene and the turbo throws a bit of Acite I bought one in the draw and I want to know if it is very difficult to ride it for economic poor people I can not put it in the workshop
13 years 8 months before #32140 by manual-mecanica
Manual-Mecanica Answer on the Re: Turbo of scenic
Not very easy. The problem is that it is a bit uncomfortable, but if you change it is easy the logic will tell you how to do it, it is to take out some bolts and make sure that the air hoses are very well tight because if not the turbo does not work, but then nothing from the other world.
13 years 8 months before #32251 by manual-mecanica
Thank you very much I did not dare because they told me something about a geringa with oil or some of that and I did not see but I saw myself to throw the bull open if Biem comes out. By the way I also listen to something that the compression had to be adjusted but I suppose it will be something else I will put hands on Tuesday or Wednesday if you know anything about what is referred to by Fabor
13 years 8 months before #32267 by manual-mecanica
Huyyyyyyyy of what you will be very old with new vehicles none of that, I have installed complete lines in Nissan, Toyota, Subaru, Renaulto Sardon and number of vehicles and nothing from the other world.
13 years 8 months before #32269 by manual-mecanica
If you can see the hoses well, if they are roasted or broken ...
