Renault Megane 1.6 16V 2001 Ralenti Alto
13 years 8 months before #32092 by manual-mecanica
RENAULT MEGAN 1.6 16V 2001 GROUND HIGH PUBLISHED BY MANUAL-MECANICA
When starting the idle, it goes well but when it is heated it is turned around 1500 and I have observed that the temperature needle is a little higher than usual and when changing the march it is as if it were accelerated
13 years 8 months before #32139 by manual-mecanica
Manual-Mecanica Answer on the Renault Megane 1.6 16V 2001 Regalnti
Czech the correct functioning of the temperature sensor usually makes a problem very similar to yours, the laps when it is at working temperature, also checks that the water system does not have air.
