Problem with Renault Fuego changes
13 years 9 months before - 13 years 9 months before #31999 by manual-mecanica
Problem with Renault Fuego's Gear Shift. Posted by manual-mecanica
Good afternoon fellow mechanics and enthusiasts. I'm currently experiencing a curious problem with my 1987 Renault Fuego. The issue is that when the engine is hot and after driving for a while, it's difficult to shift gears. Oddly enough, this doesn't happen, for example, in the mornings when I first leave the car and the engine is cold. I initially thought it might be low on transmission fluid, but it was only about a quarter liter low, and considering the clutch disc is only two months old... I'd appreciate any suggestions or similar experiences you might have. I WOULD REALLY APPRECIATE IT IF YOU COULD CLEAR UP THE MATTER BEFORE YOU TAKE THE CAR APART
Last edition: 13 years 9 months before by .
13 years 9 months before #32005 by manual-mecanica
Manual-mechanics ' response on the topic Re: PROBLEM WITH GEAR SHIFTING IN A RENAULT FUEGO
Good afternoon, please give us more information: mileage, year, engine, type of use, usual driving style, type of oil and transmission fluid. This information will help us understand the situation; even the climate is a factor to consider
13 years 9 months before #32006 by manual-mecanica
Friend. Based on the symptom you're describing, a locking mechanism in the box has shifted. When the box heats up, the metals inside expand, causing the effect you're describing.
I recommend you perform several tests to make sure it's really a gearbox problem and not clutch fatigue, as the symptoms are very similar.
Pay special attention to the engine's idle speed when it is hot and under no dynamic load, because if the engine tends to stall, the problem is even bigger and may be due to a failure in the axial bearing.
For any questions or inquiries, please feel free to contact me via email
